Abs Sensors
  RenaultSport 172
Is there any tricks to getting these out of the hubs?
I've soaked them in WD40 and used mole grips to try and wiggle it out, no luck so far.
Is it a case of keep on trying, or shall I get the hammer out?
Out of interest are they the same across the range?
And could rear ones go on the front?
Thanks. :)
TC.
I think the wire on the rears are longer and may possibly have different mounting points.
Out of interest how much did you pay for them ?
  RenaultSport 172
I havent bought any yet, just looking at options if I can't get them out of the hubs.
There's rear abs sensors on ebay for £20 a side.
  182cup & 172 racecar
You cannot put the rears on the front,they sit differently.Once you have got the little screw thing out then just hammer and screwdriver job.
Rears are about £45 each.
  182 FF
As above, just undo the torqe bolt and then work it off gently, then unclip it from behind the plastic arch liner:)
or at least thats how it works in theory, might have to pry it off with a screw driver
  RenaultSport 172
I tried tapping with a hammer adn in the end pretty much destoyed one of them so I've ordered 2 new ones. :)
