do you feel a vibration in the brake pedal at low speeds when braking? its not much for new rings from renault. they might try and fob you off and tell you they cant be bought seperately but they can, cant remeber the price but its fairly cheap!
The ABS, TC and SERV light coming on intermittently could just be that the brake light switch needs adjusting, also the cruise control will not work, it is/used to be a common fault on 182's, it will take a couple of mins to adjust it, i would try that before shelling out any cash.
