ABS + SERVICE + OTHER LIGHT..... Found guide but h=just checking.....
DaveDreads
You pull it all the way out, then pressing the brake pedal will adjust it to the correct depth,
the brake pedal switch only controls when your brake lights come on.
You may need to check the abs sensors/cables aswell,
the first time mine said SERV/ABS/ESP it needed a new one on one side.
DaveDreads
Yep you'll need a French car specialist with Renault diagnostic equipment,
probably cost about £20 to check for fault codes,
don't go to Renault they'll charge you a fortune.
Unless there's a member in your area with an up to date RSTuner box and correct software,
they can check for fault codes including brake faults,
as some of them are stored in the ABS unit.
