AC Charge only hot air?
  Ph2 172
Hi,
Had the system recharged and when the AC is on now it only pushes out hot air, any ideas?
For reference the system was completely empty as a hose was split when I bought it, so have no idea what it was like previously.
regards
  182/RS2/ Turbo/Mk1
I suspect the two faults are unrelated and your servo has just split open on the bit where it turns the hot/cold control.
Easy DIY fix if it is that, basically a jubilee or cable tie around it will sort it, there is a thread on here somewhere about it although I think you have to be a paid member to view it.
