AC Not working right (cold not coming out)
Car  Clio MkII 172 K reg
Hi everyone,
Just started my car today after 3 weeks. Everything work fine besides the AC. When I push the auto button, The compressor start to work but there is not cold air comes. I tried to switch the temp from 17C to 26C just to check if the hot air start to come out but it still stays on the on usual air flow (not cold or hot). Further more, there is strange sound coming from the heater blower.
The car is clio RS 172 2003 K registry.
The ac panel works fine.
For now, I think that the problem is in the heating switch near the ac filter.
What you think ?
What do you mean ?
For now, I want to change the resistor pack to see if this is the problem. I have a new one so worth to check ?
Ok, I replaced the resistor pack and now hot air comes out when I put 26C But still there is now cold air at all.
At the morning I'll go to regass it and will cross fingers that this will end the problem.
Ok, Today I was at renault garage. There wasn't enough gas. Refilled and since then it works perfect.;)
