acces after lowering
Car  clio 182 sport
b4 i lower my car 40mm will i have any probs getting a trolley jack under front spliter in the future cheers.
If you do make a small wooden block etc and drive onto that before trying to jack the car.
SOme trolley jacks do go very low or can be modified ie removing wheels etc
I've got one of them boggo Halfords trolley jacks.
I couldn't get that under my chassis rails on standard supsension.
Although thats probably more likely to do with my drive being about as flat as the himalayas.
I just drive it onto planks of wood under the front wheels first then have no probs.
Unsure how low i am, but I Have to jack it up slightly using the standard jack to allow my trolley jack to get under. Bit annoying but you get used to it :)
Just drive the front onto some wood made if you have a spare bit lying round. Or paving slab. Much easier / quicker!
/a few bits of wood on top of each other depending on how low you are!
If the car is too low just open the door and push the car up a little and get someone to push the jack under.
