Adding alloys
Car  1.2 Authentique
ive got the clio authentique and as you will probably know, these do not come with alloys, i am wanting to put some on, will there be any problems with doing this such as brakes and what not?
thanks
If you're swapping the steelies over for some OEM alloys there will be no problems.
im new to the modding world and may sound like a complete r****d ... but whats oem alloys compared to others? sorry for being such as newbie :P
Original Equipment Manufacturer. Original Renault alloys in other words.
OEM = original equipment manufacturer... i.e if you swap your 4 stud steel wheels for some 4 stud Renault alloys then you should be fine. Hope that helps :)
so aslong as they are renault they will be fine basically? ok thanks, and what about the brake pads will they just hook up after?
After market alloys are fine as well, but you have to think before buying (about offset etc). so if all you want is some tidy alloys to freshen the car up, it's easier to just get a set of Renault ones IMO.
I'm not sure what you mean by the pads hooking up?
ok thanks i though you had different types of breaks for alloys and steelies ... see i told you im completely new to modding :P ok so yeah all i want to do is tidy it up so i will look for some oems thanks so much for all yours helps :)
Ok thanks :) im trying to learn pretty much all the basics of basic mods, im getting there :P thanks a lot for the help
this is exactly what im looking for thanks! i have all the idea i just want to see what looks good with what :) i dont want to keep annoying you but just one more question... would you know of any sites that sell rs grills because everyone seems to add these as there first mod?
Ebay, pistonheads parts section, for sale section on here. Others will no more mate im just a NooB like yourself :)
Your best bet to find a grill is to pay your membership and have a look through the for sale section. Quite often there are people splitting cars that are damaged / engine failure etc etc.
Being as you're new to all of this, the technical guides on here alone are worth your £12. They're often written by other people who are doing things for the first time, so are very thorough and don't miss out the 'obvious' things that someone more experienced may not think to include.
as long as the wheels you buy are 4 x 100 (4 holes in a circule of diameter 100mm, aka PCD), and 60.1 centre bore (the diameter or the centre circle that sticks out of the hub that the wheel will basically sit on!). Then the wheels will fit!!
NOTE: 13" wheels wont fit over even the smallest of brakes so dont go lower than 15" wheels, and 17s look guff so dont go over 16".
ANOTHER NOTE: if youre buying after market wheels, they usually have a huge bore, then you get a plastic spacers that will match the bore of the wheel to that of your car, make sure you get these are otherwise the entire weight of the car is being taken by the wheel bolts, which is ill advised!
the only other thing worth looking into is the offset. This will be stated as ET38 (or another number), the number states how far the bolt face (the face that meets the car) is from the centre. in my case, 38mm towards the outer face of the wheel. which is pretty much standard for renault wheels, i wouldnt deviate much from that number when picking wheels that are 6.5/7" wide, (most 15" wheels).
ALL 4 bolt renault wheels will fit as they stick to the same fit, (clio v6 and new megane wheels wont).
As for brakes, theyre pretty much identical for the entire clio non-sport range, and are only slightly bigger for the sport range, both of which will fit under the wheel with zero need to touch the brakes at all!
sorry to go on, but i hope this helps!
Also, there is only 1 shop that sells RS grills, thats renault!
but they crop up on the CS for sale sections all the time!
but please dont pay too much for them, many people try and get more for them than renault charge because theyre such a sort after mod!!
struggler thanks a load for all that, so the basics of this are buy alloys the are 15/16 inches and as near to 38mm towards the outface of the wheel as possible. And i will be buying the membership soon i just have to get my insurance out of the way first :P ill take a look at the sales part once i am and also check renault to see how much one is from new as to how much i pay then. Once again thanks all of you for the help and sorry for asking what appears to be a simple question however i have recieved a lot of helpful information from it so its all good :P thanks
