Just put in some eccentric cams where your lower strut mounts are. This way you can adjust your camber no problems without upsetting your suspension too much.
As top mounts would alter the angle of the stut and spring, adjusting the lower mounts just alter the wheel in relation to ground level!!
you can buy some offset bolts from renault sport....btu making your own up aint hard, but takes a bit of fiddling and extending of upper and lower strut holes.
If you have no idead, i would NOT reccomend to start to fiddle with it.
Email me on mailto:benrushworth@hotmail.com">benrushworth@hotmail.com and i will send some pics.
