Technically it does actually mate, but it is only a negligible amount and hardly noticeable.It wont affect tracking
if your rear beam was horizontal and there was 1deg negative camber, raising the ride height a massive amount so the beam was hanging vertically down, that camber would now equate to 1deg toe out. Unrealistic example I know, but extremes are often easier to visualise.Technically it does actually mate, but it is only a negligible amount and hardly noticeable.
does it really? You wouldn't think it would affect it lol
To the same note that going down a hill will affect your camber/caster/toe if you measure from the horizontal. Basically its not worth noting unless your doing a 3" chassis/suspension lift and fitting 20" wheels to the rear.
Not strictly true , it has an effect and its your judgement as to whether or not its detrimental enough to worry about
On a road car negligable on a track car , then i would always check and regeo
If you dropped it 25mm i would still re check it it has an effect and i am just saying i would , maybe by track car i should have said race car as thats where a small effect can loose time
More like you'd have to recheck it because the rear axle has bent because it saw a bump in the road and s**t itself! Flol!Certianly the case on a race car that you would care about even small changes
Mind you, if you have Geo'd it perfectly in the first place to suit your requirements you will need to do so again after a 25mm drop anyway, as its likely to involve a change in spring rate and hence different roll resistance etc.
Flol!they are all as bent as the julian clarey fan club.
Er, so, were you asking if you need to reset the tracking on the front end if you adjust the ride height on the rear? If that's what you were asking then the answer is no mate! Lol! From your reply I suspect this may well be the case.cheers for the response people. ill make sure i set ride height out first on rear then get it tracked up
On a FWD Clio with McPherson struts and a trailing beam rear suspension it will have little to no affect, I would say the opposite to you.
On a Caterfield with unequal double wishbone suspension I might agree with you.
You'll be drooling a long time then mate if your waiting for me to do it I'm afraid fella. I'll just be carrying on doing my custom one offs as and when the mood takes me, then when I've saved up enough cash weigh the cup in at the scrapyard and invest all my money into a 997 gt3rs!I'm secretly waiting for you/Northloop/James to build an all-conquering Clio with a sufficiently over-engineered cage to allow double wishbone all round For now I shall drool over that Super Touring Clio...
