Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
The spring should sit on a threaded platform on the rear beam which you can screw either up or down dependant on whether you want to raise or lower the car.
Edit - Found a pic which shows it clearer - The platform sits in the bottom of the spring and has an adjustable ring which you wind up or down thus raising or lowering the rear of the car
i havent removed them. its just a bare thread popping up hense i couldnt see a way to adjust it.
i know the previous owner said something about wanting to go low as it was on 15s previously.
ok i need the platform. seat diameter of the spring yes?
