Aerial connector identification
Louis
I Love Ed Sheeran
Hi all,
Recently removed a factory satnav system from my 182. Because of this I'm now left without any signal for my radio as I presume it was getting it through the nav box.
I have these 2 connectors (top was going into box from aerial, bottom going into box from radio). I presume I need a female DIN to female ISO to join but I'm struggling to find this? I want to avoid using loads of connectors really to join them!
I also have a third cable from my aerial that I found disconnected in the sill trim, any idea what this is for? Is it to use instead of the above to connect to the radio if removing the nav? No idea what the connector is.
The aerial has 3 cables coming out of it as in the photo below.
Not many of these cars have genuine satnav (42 iirc) so finding information on them is hard.
Thanks in advance!
Louis
Klumpy Dumpy
Find someone breaking a standard 182 and use the standard aerial cable without buying weird connectors to join all of yours together mate
Unless any of them plug into each other?
Louis
I Love Ed Sheeran
Found this on the interwebs.
I might be getting somewhere now. The connector at the very bottom looks identical to the one from the standard aerial. So you're probably right, buy the full length cable and just connect as normal.
Louis
I Love Ed Sheeran
8200077690 appears to be the cable I need.
Wonder if the length is tucked away somewhere else or it's a different (Shorter) cable in the satnav system.
Louis
I Love Ed Sheeran
Silly french b******s🙄😂
Tbh a 1.2 aerial would work
I'm not wanting a new base haha, i reckon if I get a cable like this I can just plug and play and run it down behind the radio.
I could do with a cable like that with the female end so I can plug it into the disconnected one in the sill trim.
Louis
I Love Ed Sheeran
Yeah and unbolting buckets ain't something that you want to just do every couple of days
Saying that, it's not like you need the car atm😂
I wonder why it has the random disconnected connector in the base. I always thought the GPS was in the base of the aerial (as its longer) but all cables just appear to be standard FM coax. Might need to research more.
