AF flashing on my radio
Car  TT 225
I bought a cabasse radio and i installed correctly with code etc but now i have the AF flashing away. radio works fine but it pisses me off lol anything i can do?
in radio mode push and hold source until 'AF ON' appears, then its either the volume or skip/search buttons that you use to turn it off
but then surely if you drive any distance the radio won't hold the station? Can't remember, use dab now.
depends what you listen too I suppose, if its a localised station then you will lose it after travellin a distance, if its Radio 1 for example then their signal is quite strong and should be ok (I would guess!)
