Aftermarket bump stops to use with lowering springs
Was about to fit new genuine front bump stops\dust caps, but they seem to be huge, not sure how well they would work with a lowered spring (Eibach sportslines).
I'm not really into buying some random aftermarket bump stops, as their length and rate should influence handling massively when I do happen to corner on the bump stops for whatever reason.
Is there anything tested and proved to use in this case?
If not, should I trim some of the genuine bump stop as a last resort?
I ordered a pair of febi bilstein ones but the boot is too short on it as it doesn't cover the shaft, so I would suggest using standard. I'm oncup shocks with eibach prolines
