Aftermarket steering wheel, window help!
Car  BG 182 & 225 T
I've put a different wheel on my 182, but do you have to line up the yellow mark through the clear window where the boss kit goes onto?
soon as I turn my car on and move the wheel a centimetre the service light and traction control light goes on, plugged my car in and says it's the steering angle sensor, I remember reading about the yellow mark through the wee window last time I did it!
cheers
Sounds like you got a oreca boss? They don't have the bits on the back to turn the angle sensor, you need a omp or momo boss with the right shape on the back.
No I have a momo boss, this bit I am on about is where the wires are attached to the actual car once the wheel is off, they still spin around and there is a window that turns too
I've got an Oreca boss with my OMP wheels and never had an issue. Had it on the car over a year now.
You mean the square where the wires come out? That goes at the top along with the hole in the boss.
Oh, I just remember MicKPM having the same issues as OP. It was caused as I said above.
Oh, I just remember @MicKPM having the same issues as OP. It was caused as I said above.
Well it's right beside where the wires come out from the car, there's a clear window at the top left
cheers
Simple answer, yes!
