Clio
Hi all. Another thread to add to the millions but I can't figure this out.
2002 Renault Clio 1.5 Diesel
Story: airbag light randomly came on. Comes on when ignition lights, switches off, then comes back on in a few seconds
Tried so far:
Thanks in advance
Tried so far:
- Checked the fuse
- Checked the airbag ecu is getting power
- Checked wiring from ecu plug to underseats etc - all connects.
- Plugs under the seat - sockets were removed and wired together with a connector as had a problem before. They look fine and not changed.
- Changed Airbag ecu with one from another car - still no change
- Diagnostics - plugged in and it will detect everything else and fault codes but will not communicate with airbags/airbag ecu to get a fault code
Thanks in advance
