Air bag module location??
  172 Cup 2003
Yes mate it is. basically remove the cig lighter and little tray and you'll see it.
If you need to remove it... turn the air bags off, unplug the battery, remove the cig lighter and tray then pull the gear leaver surround up, then remove the grey large plastic bottom console section and then remove the air bag clip the unscrew bracket and there you go
Hope it helps
