I will try it.
I removed the steering wheel, but when i put it back together i have a problem. When i tighten up that torx 50 nut, my wheel is pushed against plastic and i can't turn it (it is hard).
I couldn't undo torx 50, so i hit it few times with hammer to loose up. Could i break something, although everything seems fine, except i don't know this:
Is this normal (on the pic) that this steering shaft enters the steering wheel only this little? Should it enter till the end??
