Air bag resistor.
Car  a low one
How do you use the resistor to stop the air bag light coming on? One was supplied with my momo boss, but when fitting the wheel i couldnt find anywhere i could plug it in?
Am i correct in thinking it goes into the Orange connector somewhere?
Its a Ph1 172 btw.
On my ph1 the airbag connector split into two, joined one wire one side, one the other.
If that makes sense?
Used some little connectors, then taped over them separate.
Its hard to explain, from memory it was a white ( possibly black stripe ) thin piece of plastic like connecing with an orange connector type thing on the end, couldnt see any holes or slots where i could put the resistor in it was almost solid bar the odd smaller than a pin prick hole!
or am i trying to put it in the wrong place?
