Clio Sport xxx
Hi,
Just been to get my air con regassed at a local garage as the a/c pump didnt appear to switch on when you hit the a/c button. It turns out that the a/c system was fine and reasonably air tight. The problem is something electrical! :dead: The pump it self is fine as they managed to force it to turn on by doing something with the relays, they suggested it could be a pressure switch or even just a broken wire somewhere.
What im wondering is, should I take it to a garage to fix or try doing it myself? If it's a common fault then I would just do it myself. Has anyone had the same problem?
Any help much appreciated! Cheers
