Darren S
Hi all,
I've heard on a few occasions when I've switched the car off, the whine of the system spooling down.
I've definitely not manually switched the air-con on and the A/C light isn't enabled. I never use the Auto function either - so I'm a little puzzled as to when it dictates as and when to engage the air-con.
I can manually press the A/C button and hear the dip in revs and click as the system engages normally. It just appears that on occasion, with no manual intervention - the A/C decides to start itself.
Is this a sign of a switch or sensor failing?
Cheers.
Cheers.
