Air filter
  Clio Campus
How easy/ hardis it to remove the air filter and put a new one in. Can't see any obvious clips or screws to take the stock one out.
  Clio Campus
  Clio Campus
presuming the cone at the top of the picture is what im looking for, but how do i take it off?
depends what you're replacing mate... if your putting an OEM filter back in that is the same shape, then yeah you will, but if your getting an aftermarket one, you will have to remove the whole unit to fit the new aftermarket one on :)
  FF 182
grab a haines manual? It looks like there is gonna be a clip on the bottom, are u just fitting a filter element or an induction kit? I.E K&N? Looks like the black canister may also spin off. The element should just pull out from the inside. And a garage should only be like 30 mins labour at the most. If its any more then they are just mugging you off
