Air intake, what next ?
  Clio Sport 172 ph1
So I'm fitting CatCams 412 as we speak, and I was wondering if there is anything I can do about air intake to tune the engine a little bit more :)
What I installed so far:
- Green air filter in standard 172 ph1 box
- throttle body polished by HeadTune
- RS stamped lower inlet mani, increased by another 1mm in diameter and polished by myself ( not fully matched jet but that's next in line)
I was thinking about relocating battery, and geting the air box straight to the throttle.
What would You suggest to change/upgrade to get the best out of air intake ?
  RS RIP
lose the OEM cafs and put on some uprated/bigger ones , 70mm or so
The standard ones are 50mm i think, better to get some more air in there with the cams
