AIR LEAK 172 exclusive
Car  Renault clio 172 exc
Ok, So i bought a clio sport exclusive #63. The previous keeper has put a reconditioned head on it that has been gas flowed and since then it hasn't run right revs stick at 2k 2.3k so since i've had it i have tried the following.
New injectors, New idle control valve, new intake air temperature sensor, new throttle body, new throttle position sensor, new coil pack.
since then i've been told I have an air leak so I sprayed easy start around the engine and noticed the revs change when I spray around the inlet manifold the top half joint but I have changed the gasket twice now it's nice and tight anyone got any ideas?
