Airbag ECU removal
Basically I have no airbags in the car and resistors fitted, but for some reason the serv and airbag lights are still on and on plugging in a diagnostics say that all the airbags have deployed...
Can CLIP remove all airbags and pretensioners from the system to have the lights come on and go off as they should?
If so is there anywhere this can be done?
Many thanks, Adam.
Johnpacey1
  Clio 172
From my experience resistors don't work. Get in contact with Mick at Diamond. Bloke is a genius with electrics on these!
If the airbags have been deployed it will require a new module. Otherwise, it's just a case if reconfiguring the module to the correct trim level.
They haven't been deployed, but that's not to say the ecu doesn't believe they haven't. Diagnostics gets rid of most of the codes. But a couple are permanent.
