Hi has anyone had the problem with the airbag light on. I have found that is connected to the passenger airbag the cables under the seat does anyone know how to fix it without going to a garage?
If you dont fancy soldering can either tape them up tight (will prob come loose again at some point though) or buy some two way connectors from maplins, cut and strip end of the wires and screw them into those. Ive done the latter, better than soldering if you ever need to remove the seats.
