Airbag light won't reset, all fault codes present
Hey guys, currently got my 03 Clio at the garage to have the SRS module reset and an MOT. The garage has tried resetting the module but every fault code to do with the Airbag system stays on. Would you say the module itself could be defective? The light was on originally for the drivers air bag and drivers pre-tensioner firing.
Have you had it sent off and reset.
you can't erase codes if its been in a bang.
if not a new computer will be required.
Nah, the garage its at are trying to remove the crash data with diagnostic equipment but every "fault" just stays there even if the fault isn't genuine.
It needs a proper reset or replacement. Basic diagnostic or renault clip system won't cure it.
theres a guy on ebay who does it for £20
If I wanted to go down the replacement route, is it just a straight swap if I get the same part number or does it need to be programmed or anything like that?
