Aircon pump removal
Car  RS 182 CUP
Has anyone found an easy and cheap soloution to removing the aircon pump? Just done a sear h but couldn't find a soloution. Never use air con any way only an idea at this moment in time. Any and all ideas welcome
lots of options, using both new and used parts
172 cup setup, about £450 for eveything new inc alternator, or get it from a breaker. Also need to mod or change one PAS pipe
Laguna 1.8 8v (maybe 2 litre also) essentially the same as the cup, but uses older style wiring on the alternator, £100-£150 from a breakers???
Volvo setup same alternator as the laguna but uses a pressed and lazer cut steel bracket. Alternator and PAS pump sit in the same place as cup setup. About £40 for the brackets from a breakers yard, or ~£70 from renault if you can work out which model they are used on (saffrane maybe.....) plus an alternator
