Alarm but no LED?
Car  Clio 1.4 Dynamique +
My car has an alarm fitted (has interior sensors, bonnet switch etc) and works perfectly but where I assume the LED for this is meant to be (next to gear stick), I simply have a hole with a black led surround in it but no actual LED. Is this normal? Should I have an LED? And if so are they east to retrofit?
Thanks,
DaveB
Chances are it's just fallen inside - if you pop the gear lever surround off you should be able to see it
Are you sure the alarm works - as obviously the central locking would still work off the keyfob in the same way even if the alarm had been removed
Nice idea. That hadn't even crossed my mind - I'll have a look later. I take it the surround is easy to pop off?
yea it should just pop off mate. As mentioned, its either falled inside or some1 has been prodding with it and pushed it in!
182_Tom, cheers for the input. All sorted. It looks like it had fallen inside. I managed to get to it by taking the ashtray out.
