Alarming discovery!
Car  LOTS!
Hi Folks,
Can anyone tell me if my mk2 2001 172 has an alarm fitted as standard? or do I need to get one?
How can I test the existing alarm if there is one? without breaking into the car obviously!
Jono
use the blade of the key in a door and open the car, alarm would go off if fitted. Also, if an alarm is fitted you will probably have an additional red flashing light in the interior of the car (seperate from the one on the dials)
Quote: Originally posted by Jono_GTi on 28 April 2005
HPI check says its not an import...
id be getting worried or a second opinion then if it doesnt have an alarm
look for window etching on the glass m8, thats a give away, ring renault give then ur vin number and see if they can chase it up for you
Quote: Originally posted by RacerStu on 28 April 2005
I found a good way to set the alarm off is to lock the car but leave the windows open.
I read in a thread here before that you can actually turn the sound sensitivity off, thereby allowing you to lock the car but leave the windows open. I just cant remember how its done... anyone?
