Alignment settings
  LY R26 #288
I'm a bit confused. From what I can gather a 182 should be set to 12 degrees toe out according to the f4r PDF and the figures Edde has posted in the guides section.
Is this correct? Every time my alignment gets done they set it to 12 degrees toe in.
I always thought toe had to be slightly in to compensate for accelerating etc.
Tell me about it. I had it done on the hunter system but they set it to -12 degrees.
I would have thought +12 degrees toe would scrub the tyres out quicker? :s
12 degrees? - you mean minutes. But yeah, it should be -12 (or around about 1mm toe out). See the thread ^ he ^ started.
