ALL CLIO OWNERS
Djw John
Scotland - South
What for? Your amp? What year of car?
If it is and its the latest shape, use one of the bolts for the black bar at the back of the boot.
  Shhh
You could alternately run a seperate earth along with the power cable. How about running a temporary earth from the battery to work out if the amplifier is damaged or inop.
As to earthing in the boot. If you find a bolt within the surrounding area that goes into the chassis of the car, remove the bolt if you can, remove the paint under the bolt with some sandpaper taking care not to remove too much..thats not required, treat with rust killer, and loop the cable too it. Fasten bolt up, and con check it with a multimeter to find out the resistance to the earth. You then know that its hunky dory..and connect up to the amp.
Job done..
  Volvo S60 T5
Da ting is dat da amp may not kick out dem good toons, so I fink it da amp fooked 2, get down da blingin ICE store and get da best muddafooken toonage sytem fitted and pump out dat bass!!;)
