all sort of problems
  Clio 182
rite well to start off with the outside temp is saying 40 and it is like -5, the climate control demisters do not go on full and stay on half way and finally abs traction and serv comes on when i turn the key before starting engine, then go out a second after the other lights this all just happened today so if you can help that would be great thanks.
Abs = Abs Ring might be knackerd?
de-misters = duno
Temperature thing under the wing might be broken.
Im just guessing, could be some salt/ice etc which has nackerd the ring on the shaft, or the Abs sensor itself on the hub, try and get it on diagnostics machine that will say what it is
The ABS, TC and Serv lights going off a second or two after the others isn't a problem. I'm sure they all do it. You probably just never noticed before.
