Alloy to Steel Wheel bolt Help needed!
Car  clio dynamique 16v
Hi there,
I have a Clio 1.2 dynamique, and I have just bought some new wheels for my Clio. They are effectively a deep dish steel wheels.
I test fitted them and noticed the bolts from the stock alloy where too long for my new wheels. I've done as much research as I can, even rung up renault parts in my local area (who couldnt tell me the correct bolt size, but could tell me that i will need new bolts) and i just can't find out what the name / size of the bolts are that I will need. If anyone can send me a link to a set of bolts that will fit then that will be perfect.. if not just the details so I can look them up myself. (im looking for black or chrome / stainless steel bolts)
Many thanks!
the diameter of the bolt (should be the same across clios), the length needed (current length minus amount of poke) and taper angle needed (not sure on the best way of measuring this as it is dependant on the holes in the wheels)...
thank you for your help! do you recon itll be easier popping into a garage with the wheels and explaining? see if they have any lying about to test it out with?
Went down my friends garage today and they said that the bolts from the alloys will be okay to use on the steelies! thanks for your help tho!
