Alloys & lowering
If I got 15" wheels for my mk.1, would it look OK for a while without lowering it, or would I have to lower it a bit at the same time to keep it looking ok? Also, does anyone get any rubbing with the 15"?
15s are probably the optimum wheel size for the Mk1 non-wide arch (i.e. not 16v/Williams) Clio. I fitted 15s and 16s on my old 1.2 and the 15s were easily the best - slight rubbing, but it was lowered to the floor. 16s meant major rubbing, poor handling (not to be confused with grip) and poo acceleration/top speed.
On a 16v/Williams or a Mk2 Clio, 15" is a bit on the small side for an aftermarket wheelset - besides, the 16v and Willy look best on the original 15" wheels.
I used to run my clio on just 15"s for a while, it didnt look bad but just lowered it 60mm at the back and 35mm on the front, keeping my 15"s and looks way better! Still thinking of lowering front more, if u wanna pic send me an email or PM me
I have it lowered to the top of my tyre on the back (195/50/15) and it rubs on the inner lining over bad bumps with just me in the car. With someone in the back, you can hear is scraping - I also have a line around my tyre wall where the inside arch has rubbed.. Gotta get that lip grinded off methinks and the lining removed.
Lowered -35mm on the front, and it rubs slightly on full lock on the inside of the arch.
Hope this helps,
Daz.
Mines droped 55mm on the front and a bit lower on the back running 15s on 45 pro tyres no rubbing what so ever even with 3 other people in the car. Still got the linings although I have moved the rear ones slightly. I wouldnt think about putting larger than 15s on mine purely for performance and handleing reasons. If your after looks then 16s will look better.
