Weeksy Car ph1 172 Excl, Cossie May 22, 2014 #1 Hi Guys, Does anyone know the bore size of the master cylinder fitted to the ph1 172? Are there any larger bore fitments that are a straight swap? Was thinking later Clios / other Ren's etc? Your help would be much appreciated Thanks Weeksy
bozothenutter ClioSport Club Member Car FF Arctic blue 182 May 22, 2014 #2 I have been told a Clio3 RS should fit, is a mm bigger (didn't fit a LHD car though, that needs a laguna I MBC)
Weeksy Car ph1 172 Excl, Cossie May 22, 2014 #3 I had hoped something later would fit, and would be a good pairing seeing as they also run calipers with 4x 40mm pistons Thanks a lot dude Weeksy
