Am i being thick?
  Inferno 182 CUP
Or does my 133 have 3 silencer boxes?
lol
And will cutting the middle one out do me any favours on the chav noice front? I want louder!
  53 Clio's & counting
The middle one looks most cat 'ish', though it may have a pre cat under the manifold.
I wouldnt cut one out no mate, get a different exhaust if you want it louder, exhausts are made to produce certain back pressure, and cutting a box out will alter it
  Inferno 182 CUP
I cannot afford a new system :( Missus lost job and works a biatch atm .. wanted more noise the easy way :(
lemonnobby
to be honest i would cut the middle one out but cut it out so you can put it back in if theres any problems
  Inferno 182 CUP
what is the middle one and then the front one :S
are they both silencers? if so why different shapes lol?
  Evo 8 MR
Different shapes and sizes reduce the sound differently, I don't recommend cutting anything, either leave it standard or do it properly imo.
It will sound like it's blowing ie. a tractor, if you cut silencers out.
Are you sure these have cats in the manifold? The K4J and K4M engines in the mark2 ph2 clios had proper seperate cats.
  Inferno 182 CUP
Yeah 99.9% sure cats in the manifold .. the ktec system is a catback anyway .. and that goes up to just before the manifold :)
Da
  Less
Yeah no Cat in the pics as there's no lambda's to go with it.
I personally wouldn't cut anything out, exhausts are manufactured to perform. Cut a box out and it may sound better but will have undoubtedly lost power.
The_Pirate
  Golf R
Take the cat or baffle box out (centre section) and your car will sound like a Lion thats just been shot in the arse with a tranquiliser dart.
p@blo
  Clio/A3
Not sure about the twingo but my k4m has a short mani & a gooseneck cat that sits right about where the mystery box does on yours. Have you not considered a different airbox setup?
IMO, butchering your exhaust sounds risky to potentially end up down on power/torque for the sake of how itd sound.
  172 cup
if the cats in manifold then yes theres 3 silencers, personally if money was tight Id get a universal back box
  182
drill some holes in your airbox if you want a bit more noise lol, wouldnt cut away at a exaust thats in working order
  Inferno 182 CUP
wouldnt it sound okay though having the rear backbox still in place to do its duty?
god i need £300 :(
