amp help
Car  20VT Clio & 9-5 HOT
to cut a long story short i got an amp and when i wired it up it just flashes protect all the time. and i can occasionally hear a little bit of noise through the amp. im certain its all wired up ok!
yeah gains are down and the wiring is from my existing setup which worked spot on so should be fine. got a good earth etc. good wires!
hmmmm
check that the power and earth are connected to the right connections
very easy to get the two mixed up without even realising (i.e. + connected to -, and vice-versa)
