AN hose assembly lube?
A little bit of hydraulic oil usually - stops you contaminating your hoses with silicone from WD40...
Thanks for your advice. Just finished the last fitting, the teflon line is the return from the rack and the blue is the high pressure, was not easy to do those fittings, there were about 40 threads to turn lol
With some heat sleeve as well
