Lol at the jesus. Lol at this thread.
And why the hell did you spend near £300 on a sports cat thats almost the same as the standard 182 cat??
Im pleased with my mods.
I think you will find the RS inlet on 2004 onwards which means it is on the last of the 172's. My 04' plate had one fitted, not any longer as I exchanged mine at AWT knowing they would be the same once machined and that I would possibly gain less over an earlier inlet, hence the reasoning that earlier models respond better to this mod, even tho it might not be physically noticable......could you tell the difference with a 7.0 sec. 0-60 over a 7.2, I defo couldn't, becuase i'd imagine this is all were talking about. Maybe in gear 30-70 might be a few fractions of a second quicker too or half a car length.
The reasoning behind combining this mod is to maximise the gains as alone it is very little and unoticable.........IMO
Adam, highly unlikely you will have an RS inlet, if your considering getting your inlets done I think the re-map is worthwhile. Might be worth putting mine and yours back to back and then you will see if mines quicker. BTW....did you have agood holiday![]()
a lot of hot air here.
As Rich says, you are only fine tuning the engine making it rev easier, adding some more midrange torque etc.
IMO Sports cats are a pointless waste of money, granted they will pass the MOT, but if your going to go to the extent of changing the CAT anyway why not just add a de-cat, and put the CAT back in come MOT time?
I cant justify spending a load on my engine, ive an exhaust, decat, BMC CDA and paul will be re-mapping it after FCS at some point.
Spending £1200 on these engines isnt going to give you a totally different driving experience in terms of power etc.
If your after a huge difference id probably fit throttle bodys, shoehorn in a VAG lump or even better sell it and by something quicker.
Pauls Meg 225 goes like s**t off a shovel. And power can be more easily gained for less money.
my 2 pence worth...
my 2 pence worth...
Best Clio mod is free
weight loss
what mods you done, thats a good increase!!
