Another PC problem...
  Civic Vtec y0
My PC has been running very slow for the past while, so deleted everything I didnt need and done a disk clean up then a defrag, thot that might help but no! Do a virus check, turned up nothing...
Pressed Crtl, Alt and Delete and my CPU usage is at 100% all the time, even when there is no programs running and it is just at the desktop?
Any one have any suggestions?
  Der Panzer
Yeah, clikc on the process tab in Task Manager. Me thinks Malware.... or more dodgy Belkin wireless b****cks.
  UR 197, AB 182 FF
Sounds horrible
Kill the process, try and prevent it from starting up again using mcsonfig -> startup
Get yourself spybot s&d and adaware personal and do a clean sweep of your machine. might be worth running "Hijack this" too.
  182
click it and click end process. Check ur pc still works ok, if something stops working restart it. If ur pc appears to work fine it could be spyware.
  Civic Vtec y0
I have ended the process and the PC is still working fine, so it is most likely spyware so downloading Spybot S&D... il let yuou know how it goes
  UR 197, AB 182 FF
Sounds normal for windows xp to me...
In all seirousness though, no it isn't good. Get rid. and stop using IE!
  Monaro VXR
^its still IE. still has most of the same security problems. Just tarted up to have similar functionality to firefox.
  UR 197, AB 182 FF
Daz182 you need shooting for recommending IE7. It is riddled with problems!
Firefox + Adblock + Noscript = Winner.
