Long story short I've got that starting gremlin problem. No Fuel pump or Spark on key on.
Immobiliser light stays solid on key on, starter motor running for 3 seconds then goes out, I've changed the crank shaft sensor still not starting, RAC checked all electrical relay connections and battery ect.. and swapped the three black relays still nothing and was unable to connect to the ECU. I have checked and found supply from fuse 5A to terminal 38 ECU ok and returns 3, 28, 33 & 67 ok, 30A supply ok to the fuel pump and injection locking relay, 15A fuse feeding fuel pump control and terminal 29 ECU ok, cables to the TDC sensor 54 & 24 ECU ok I bypassed the B2 terminal down to ground on the fuel pump relay, pump runs but still not starting, opened up the ECU all looks ok. The drawing im working on shows terminal B2 (fuel pump relay) return going to ter 9 ECU but when I checked there is no cable in term 9 ECU getting dark so will have to check that tomorrow, but in the mean time any technical advice would be greatfuly received.
