BE CAREFUL! I used crazy force and it worked on em all, apart from the passenger side 3/4 one, I pushed too hard and put 2 dint lines in the door panel
found a solution! get a old, thick wire. pull back the front of the front strip, or rear or rear strip, and pull in oppisite direction. works for me every time
at the front of the rear trim, put your fingernails under the bottom and pull it out 1mm tap back and it drops off theres a retaining lever in bottom front corners
