Anti Roll Bar Fitting Kit
Car  Clio 182
Basically, ive somehow lost BOTH bolts and bushes which connect the wishbone and the bar. Does anyone know or could find out for me the part number for these bits and also how hard are they to fit, whether i can do it, or need a garage to do it.
You can do it yourself, you just need to raise the front of the car up both front wheels off the ground.
When changing the bush you need to get a big bar on the wishbone and a jack or stand under it to compress the middle rubber bush.
No, its a mk2ph2. Just got off the phone to Renault Harlow and they've said £5.47 plus VAT each. Cheaper than i thought! Any idea how long it'll take?
If its completely gubbed you'll feel it, and it the top part flys off, the arm will clunk and bang loudly when turning. You shouldn't be able to pull the roll bar down with your hand.
