Any consequences to running my laptop charger without a ground connection?
  Mk2 Golf GTI
I was getting loads of interference through my speakers and external monitor due to the ground connection of the charger.
As a temporary solution, i took the ground wire out of an extension lead and now plug my laptop into that groundless extension whenever i need to record some audio.
All the interference has disappeared which is good, but i'm just wondering if running the charger without a ground is going to cause any problems like shorting out or totally blowing my computer up?!
It's a windows laptop with a plastic body, if that makes any difference.
  Polo + Micra
depends if there is a 3 pin or 2 pin connection on the input of the laptop psu
if it's 3 pin then i wouldn't use it without that connected
also having an extension lead without the earth connected is a big NO NO
  Mk2 Golf GTI
It's a 3 pin, clover leaf shape thingy.
What about if i plugged the extension into a surge protector? This is only temporary until i find a proper solution! And it's only left like this for an hour at most with nothing else plugged into it.
When i finish recording i just plug the lappy charger straight into the wall.
Any idea where i could find a 2 pin laptop psu with the figure of eight shaped connection?
If i had something like the one below would that solve my problem?
