Any home remedi brake dust remover?
Car  Petrol Blue 182.
going at it with hot water and washing up liquid, using a dustpan brush and a toothbrush lol. Does anyone have any secrets on how to remove brake dust with house hold objects, other then washing up liquid?
Some sort of wheel cleaner might shift it?
I've got some pretty abrasive stuff if you want any..
Bilberry wheel cleaner or intensive tar remover works quite well if you leave it on for 5 mins first.
Wonderwheels - buy it anywhere
someone will be along to tell you that it'll dissolve anything it touches though
Fairy power spray + toothbrush + aggressive clay + several hours elbow grease is the only thing that worked for me!
Tardis etc budged a bit but not the majority of it...
Vinegar should have an effect on it.
Oxalic acid is very good for removing such things, but you have to be careful with it. If you decide to use it and get hold of some, let me know and I will give you detailed instructions on it's use. :)
