Any one have a stock ecu bin file ?
I assume you're looking into TunerPro or similar? You're brave... I don't have a clue what I'm doing with ECUs! Have never touched OEM and only ever poked around with MBE Easimap on the Westfield after having it professionally mapped :S.
Here are the RST and Cal that I pulled off a stock 182 as a backup with RSTuner before sticking fastchip's map on it.
http://www.edwardb.co.uk/Clio/RSTuner_8000_7802_2011-10-21_15-52.rst
http://www.edwardb.co.uk/Clio/RSTuner_8000_7802_2011-10-21_16-07.cal
It's not a bin I know, but hopefully will be of some use. Just had a quick look in Hex Editor it doesn't look as hideously encrypted as the ECU Software and Calibration files that Henk then sent through to upload on that car.
FWIW as there's always debate here as to which files to use, after sending Henk a screenshot of RSTuner connected to that car the files he sent through to use on it were RSTuner_8200_7804_OEM.rst and RST_EL_1855_Clio 182 8200_7804_F4R738_RON98_1110_.cal
be careful making any .xdf files, there's several different versions and and the maps aren't all in the same place.
