Anyone able to help me please? Essex
  Golf 7.5R & Clio 200
Hi,
I have a 182 that recently had a PMS Aircon Delete kit fitted with a new Aux belt.
But in fitting the kit you lose the standard tensioner and it's a strange nut and bolt thing to tension the belt.
I have worked out how to tighten/loosen the belt, but it's making funny sounds so I don't think inhave the tension correct.
I don't suppose anyone would have any ideas and be willing to take a look? I'm in Benfleet, but can travel with the car (starts and drives).
If not I'll try a garage, but as the setup is strange not sure if they'll be able to help.
Ry
  172 Ph1
What belt are you using ?
Once the belt is tensioned , you shouldn't be able to twist the longer length by 90 or feel any slack at all
Yes thats the set up. We used a Dayco belt.
Will get some pictures later of the tension and see if I can upload a video of the noises
  RS197
I use a guy in Southend who's always sorted me out, if it's an easy fix he'll just do it on the spot and chuck him a few pennies. Let me know if you want his details, he only works on Renaultsports
Sent from my SM-G935F using Tapatalk
What is making funny noises ? The pulleys, the belt, the bracket its self ?
When I fit mine I just go for a 5-10mm of play in the belt, been on a few track days with it now and it has been no issue what so ever
