Anyone fitted sub/amp west yorks area?
Hi guys, Ive just purchaced a sub and amp to go in the boot of my 182.
I am usless at ICE/electircs, so just called a company for a quote for the instalation, £80!
Is there anyone in the west yorks (Halifax) area who is good at this and has done it before in a clio?
Fancy giving me a hand for some beer tokens?!? ;)
Cheers..
Easy enough to do, I ran the earth to the rear seatbelt bolt, RCA and remote cable down the driver's side, the plastic trim by the carpet unclips and you can push the cables up and clip back. Did similar on the passenger side with the power cable, depending on your thickness depends on how easy it'll be.
If you already have an inline fuse attached, you need to feed it from the bonnet into the passenger footwell, used the hole where the bonnet release cable goes through. Unfortunately, I had to pull the gromit out as I couldn't fit the power cable and the bonnet cable through the gromit together, personally. Some have I think. Run it up to the boot under the plastic trim and jobs a good'un.
Pm me your postcode and ill tell you how far away I am, if you still want my help then Ill trek down/ you trek up. Have you got a wiring kit?
