anyone used the k-tech engine mounts?
I have the top mount in mine for a couple of k now without any problems. There's a slight increase of vibration at idle and the cabin was noiser than with a standard mount. I took mine off again today and cut two pieces of rubber to fit underneath, which has improved the vibration/noise considerably.
got all the ktec mounts in mine, good upgrade on the worn out ones tho i couldnt say if you would have the same results with just buying new oe ones?
Ben who's built/run that solid bottow mount? looks ace, completely eliminate the bottom end movement! only concern would be the stress the rest of the mounts take :dapprove:
alot of the mk1 lads run rose-jointed stabiliser, without problems. It allows more precise gear shift.
It technically isnt a mount, as the name describes it stabilises the engine. So it doesnt necessarily stress the mounts.
i had a look at a cup racer a couple of weeks ago. I asked how the engine was mounted; where the mounts were ; engine is bolted straight onto chassis !
The Sadev box would'nt work with a moving engine, it would keep coming out of gear
I think when stiffening/ taking all the movement out on the regular RS you will get gearbox problems ; sudden torque-jolting will push the box apart because of the gears not having the "straight" teeth ?
I think some play is best for the box..
you definitely don't want solid engine mounts in anything other than an out-and-out race car - they'll feel unbelievably harsh in a road car
still haven't the funds spare but, as soon as i have, i'll be giving the KTEC/Vibratechnics mounts a go. stiffer mounts made an enourmous difference in my last car and the Clio's mounts are pap, so hoping these will help
lol, thinking of fitting the topmount with just a new renault gearbox mount and then making ones of those solid dogbones up
http://i7.photobucket.com/albums/y270/whiteley/IMG_1658.jpg
But it looks like it will break everything else? lol
thoughts?
I fiited a new renault gearbox mount and then fitted the ktec top mount and i have had about 1500 miles of trouble free motoring so far.
I did find my dash vibrated a bit after but I have made it better by fitting some rubber under the mount.
afore mentioned solid MK1 dogbone mount is known as a "coops" dogbone iirc. Give him a PM about them.
If I were fitting a solid dogbone to a MK2, i'd be worried about the bolt hole where it connects into the gearbox. People have had problems with the poly-bushed dogbones striping threads out where they are mounted to the gearbox. I don't think it's fair to say that this WILL occur on all cars fitted with a stiffer dogbone, but if your fitting a SOLID one......that's even more stress.
On a MK1 you don't get that problem because of the much better way in which the dogbone connects to the gearbox. (MK1 FTFW ;))
As for the extra stress put on the other 2 engine mounts, I'd imagine there would be some, but nothing to really worry about. Just keep an eye on them.
So to summarise, sell up and buy a MK1!
Mark is coops a user on here that produces them or gets hold of them? seriuosly tempted to run some thing like this over a poly bush one, any one got an idea onn price? how many people have ran these on Mk'2s?
phs1 dogbone mount ftw! (same as mrk1)
afaik they havent been run on a MK2 yet. "coops" is the owner of a particularly sweet valver turbo, and he's on CS, williamsclio.co.uk and clio16valver.net
I've only seen the MK2PH2 setup, wasnt aware the MK2PH1 dogbone setup was different:cool: The thing that makes the MK1s stronger is the black support section that is bolted to the gearbox in 2 places (with no threads in the soft ally gearbox either). The dogbone just bolts up to that. Far better solution, shame they didnt carry it through.
Edit: he's not on here, but he is on WC.co.uk
There's an email address for him on there, drop me a PM if you want it.
i know, but if there less than £15 sheets then its not worth the hastle
How mucho are they stan*?
you could space it out with nuts, tube etc
But i need to know the OD of the renault bolts
Im just going to buy one of coops ones matey..
Ill let you know when he confirms a price :)
So Coops one comes complete with the spacing parts then? If not & you manage to get one finnished/installed keep us updated please mate, will suscribe to the thread ;)
just checked on C16V and they are 20 odd quid new from coops he does group buys from time to time.......has to get so many before he will do another batch etc
