Rob
Easy to say when it's not your $$$
Easy to say when it's not your $$$![]()
tbh with a sata 3 SSD, rams pretty much a moot point these days anyway as you can load from the drive that quick that the 'unused' bits of CS not in RAM can be dragged back into use stupidly quickly
I use lightroom on 10gb and if you watch the performance monitor, even with 20+ ie tabs and iTunes etc all open too it used about 60-70% of the memory at any one time absolute max.
If it was loads of money i'd understand the hesitation, but its not.
Like i said, its all entirely up to you.
If you cant afford it then fine, make do with 8gb.
Sata 3? MBP is PCIe
Sata 3? MBP is PCIe
Agreed. May as well.
Does the EDU discount apply in this case?
I just checked it does, so that brings the cost down on the optionals, its not much. Looks around £10 off the ram.
(i'm looking at my personal employee discount not the EDU which i think is more)
Just out of interest, @Tom and @Rob, is there any reason not to go with a superior machine without the Retina display for less money?
For example, non-retina 13" MBP for £1,100 comes with a 2.9ghz i7, 8gb RAM (yes I appreciate the aforementioned points about RAM) and 1TB of storage... Other than the screen, that reads better to the un-educated that the Retina offering?
You said the word photography. It's that simple. The retina screen is sublime and photo editing on it etc is excellent. Not to mention the residual value.
The non retina will likely plummet in a few years.
Also, that 1TB isn't SSD, if she takes A LOT of photos, I'd buy her a proper tiny external drive and then not store them on the SSD, or at least archive once every 6 months.
She's also half blind in one eye. I have to read words off the TV/Cinema screen for her. But get what you're saying. Another thing to test side by side.
Appreciate the SSD thing as well.
I got 16gb upgrade because I know i will have this machine for the next 3 or 4 years and divide the extra cost over that period and its worth it every day of the week.
f**king hell, well done!
I don't think you've ever surprised me.
@Rob, another consideration from testing them out on Tuesday is the fact that the new Retina display ones no longer have an onboard disk drive!! Appreciate they'll be thinner and lighter without, but that's something she wants and needs. We also couldn't tell much difference between the Retina and standard displays, so have a feeling she'll go for a top spec non-Retina one.
